Flysky issue
Brandon240
So I have a flysky fs-i6x transmitter with an Fs-ia6b receiver and when I plug servos into channel one and two they move wildly everywhere with no control and I get a beeping from the transmitter, does anyone have a solution to this? Thanks
Still not working, thanks though
I would go through the menu to see if there is a range check item.
I’m thinking the idea is to put Tx down and carry the plane away with servo moving. If you had a range issue, the servos would quit moving.
daxian
fs i6 does not have range check ...what amp esc /bec do you have connected ?? if not enough amps in the bec would cause servo jitter...
