Hello All,
I'm trying to set up a GPS guided Kraken with FPV using the FrSky RXSR-FC Omnibus F4 Fireworks V2 Flight controller. I'm fairly new to this and have never attempted anything this complex before so please excuse any incorrect terminology or stupid questions.
This FC has a built in PCB, OSD, Barometer, hall current sensor and gyro. It's built for quads but supports Betaflight so I thought it would be fun to try and make it work as a Autopilot for a plane. In betaflight I should be able (hopefully) to remap two of the motors to Servo's to control the plane (M1 and M3). However as the Servo won't take the voltage from the battery so I'm powering it off a 5v rail (not sure if this will work). Also I've read sometime you have to do it in certain pairs so I might need to do M3 and M4 as servo's.
I did up the below wiring diagram to show how I think it should all be soldered together but I'm not really sure if this is even possible let alone feasible.
If it isn't possible to run the Servo's off the motor pads I may be able to use an SBus decoder to add 3 servo's in but I'd rather save this as I'd like to add retracts and a pan tilt for the camera (to link into head tracking) later.
The components I've chosen are in the diagram and listed. I'd like to record the on board footage but I'm not 100% sold on using the Mobius mini. I'm powering it off the 5V_Bec as it can't handle any higher voltage.
I've attached the FC board layout, my wiring diagram (which induces the GPS and camera/VTX) and specs sheet for the RXSR-FC Omnibus F4 Fireworks V2. My Transmitter is a FrSky Taranis x9d+.
If any of my components are wrong, it's wired incorrectly or if this whole idea won't work please let me know. Thanks for any help!!!
