FT Corsair
FT Corsair 1.0
flitetest
Administrator
Admin
flitetest submitted a new resource:
FT Corsair - FT Corsair Free Plans
FT Corsair
Designed By: John Overstreet
in collaboration with Flite Test
Plans By: Dan Sponholz
View attachment 124840​
Description:
The FT Corsair represents a new chapter of Flite Test scratch built aircraft! Using techniques developed by John Overstreet which he has also used in his metalworking, this plane uses "mold together" techniques instead of the traditional "fold together" techniques that Flite Test planes...
Read more about this resource...
Mr. Gandalf
Whoop Whoop !! I love the corsair and this is a fantastic model, but seeing as my hobby budget is limited to birthday money, I have to build from plans. As soon as I get a power pack c equivalent motor ( two actually) I am going to build this and maybe even the A-10!
Gladiator
I think I'm going to make this one. Can someone tell me some alternate parts for this build as I don't think I can get the same parts here in India. Also, I was wondering what is the recommended thickness of the Foamcore used in this build. Assuming the foamcore used in the FT Corsair video to be same as this, I'm not able to identify the thickness. Any help with be appreciated! Thanks. 😃
Tench745
I can tell you that the FT and Dollar-tree foam board is about 3/16" thick, probably closer to 4.5mm.
wov
Hello, I replicated the spars in Fusion 360, because I needed the DXF for milling the parts on my router. In case you want to do the same, here are the files.
Wolfgang
  • corsair_spars.zip
wov
What a great plan. The parts go together really good. Building the Corsair already is great fun. This is my result after the first few hours. Thanks Flite Test for this plane!
evranch
Didn't have anything on my build list... now I do. Love the smooth look and the appeal of trying some new foam techniques. From the flight video it looks like a great scale flyer, too.
wov
spar skeleton is done. I followed the video when John applied the hotglue to the wooden spar and then pressed the foam parts on top but quickly realised that, as Josh Bixler pointed out in the FT Spear build video, the hotglue cools down very quickly when applied to wood. It is therefore highly recommended to apply hotglue to parts made of foam and then press them firmly on the wooden spars.
wov
it should be 2.4 mm, which is impossible to find in Europe. I used 2.5 mm which shouldn't make a difference.
Tench745
It's been suggested on other forums to pre-heat wood or metal before you apply hot-glue as it gives you more working time. Less than a minute in an oven or toaster-oven will warm the wood enough to let the glue work in and lay flatter.
Often times glue is applied to the non-foam material first to get it to adhere there first when it is the hottest and then apply the foam, because even a cooled glue will stick OK to foam board.
If you want a great bond between wood and foam, use Gorilla Glue.
thenated0g
I did my spars yesterday from the speed build kit. I use a hot glue setting (not a low setting) and put on a good amount. It didnt have any issues, but i was also pretty quick. I have had this cooling down happen though on coroplast and EPP. I have found that when having problems that i apply hot glue to both surfaces and than its becomes one when stuck together.
Really enjoying the "curvy" airfoil of the wings.
PaulK
Really wish the Individual download files were more specific because I wanted to make the full size model and not the smaller one
Jerry_C
Funny, I was sitting here putting the finishing touches on my modified Guillows F4U-4 Corsair when I decided to check out FT and see what they had new. Yeaaaaaa, I'm gonna have to build this. Down loaded the plans but will probably buy the kit. I really hope they do a large mustang.
sundown57
finished the FT Corsair scratch build yesterday, What a fun build this one was. Challenging yes but very doable. They say someday it might stop raining so if it ever does ill let you'all know how it flies
Wildthing
That looks really good, nice build.
