Specs, Parts List, and Build Guide(Rough draft, no pics)
Specs
parts list
*Motor: FT Radial 1806 2280kV
*ESC: FT 20A
*TX/RX
*Prop: 5x3x2(efficiency), 5x4x2(well rounded performance),5x4.5x2 Bullnose(thrust/speed/power), 5x3x3(high alpha, best slow fly and biggest speed envelope with good top speed, aerobatics)
*Servos: 2x 9g(or 5g if you prefer)
*Extra: 2x servo extension cable
FT Techniques Employed: A fold( one small segment of the nose box), paper removal and curving(two small front plates on the nose box)
Vimana89 Techniques and Methods Employed: two layer spine(for planes that only have a nose box/ nacelle fuselage rather than a full box, and also have a one layer wing, my two layer spines provide structural support and a good launching grip. The spine runs along the underside of the wing and keys in to the nose box.) Velcro hatch(Skewer holes annoy me, so I'm working on hatches that open and close only with Velcro. This design features one that comes completely on and off with no hinge.)Vimana89 style hand held dihedral gauge(The gauge I will provide is not the usual style that sits on a surface like a table or work bench. It is well suited to smaller and/or low aspect wings. The wing is held in one hand and the other hand holds the gauge against the crack while the glue sets, allowing the builder to hold it fully steady for quick and easy dihedrals requiring no surface and possibility of the gauges falling out from underneath or anything annoying like that.)
Building from Printed Plans
1.)prep: If you prefer to cut out all pieces before assembly, do this now. Otherwise, start by cutting out the wing and dihedral gauge.
2.) wing: Take the wing blank, and make the score cuts to crack your dihedrals and elevator. Crack the elevator, and cut and/or sand your bevel. Reinforce as desired with tape, glue, etc. Your elevator should be a complete and functional hinge, ready for linkages. Crack the dihedrals, and set them one at a time using glue and the provided gauge. My gauge is different than some in that it is held in one hand while the wing is held in the other, rather than sitting on a surface. After the elevator and dihedrals are ready, cut out the tab slots in the wing for the vertical stabilizer(x1, rear), and the nose box(x4, front). Your wing is now complete. Set it aside.
3.) nose box/fuselage: Cut this piece, the corresponding plates, and the two piece motor mount out if you have not already. Score cuts and remove foam as indicated for the small A fold at the bottom of the box. Glue and set your A fold. Apply non-curved plates(back plates) to the fuselage. Apply two-piece motor mount to firewall, and mount the motor if it isn't already attached to the firewall. Glue the sides of the two-piece mount, and fit it into the front of the nose at desired thrust angle. Once the motor and mount are in place at the desired thrust angle, remove paper from and curve the top and bottom front plates. Apply these plates, and either before or after, cut your desired cooling/venting holes. You should now have a mostly complete nose box just awaiting the top hatch and cockpit. Set this aside for now.
4.) Vertical Stabilizer: Cut this part out if you have not yet done so. Score and crack the rudder, cut/sand the bevel, and reinforce with tape, glue, etc. as desired. You should have a complete vertical stabilizer with functioning rudder hinge, reinforced, finished, and awaiting linkages. Put this aside.
5.) Spine: Cut out the two layers of the spine if not done already, and glue them one atop the other into one piece, as sturdy as you can manage without overdoing the glue. Your spine is complete and can be set aside until it is time for assembly.
6.) Air Frame Assembly: Start by mounting the VS/Rudder to the wing, making sure it is flush at a 90 degree angle. Next, mount the nose box, making sure everything lines up right. remove the paper from one side of the top plate and apply it over the tabs/slots that attack the nose to the wing. This is for both aesthetics and extra strength. Finally, apply the spine, using enough but not too much glue, especially around the sides of the key, and keying the front part of the spine into the back of the underside of the nose box as far as the key reaches until all corners fit flush. Make sure your spine is aligned dead center and not skewed at an angle before gluing down completely.
7.)Linkages and Electronics: Install linkages and electronics as desired. The nose box really only has enough room for the battery and ESC, so the receiver will have to be mounted some place else, such as the top of the wing. Servo cables can the through-wired and taped along the length of the spine. When everything is in place, and the only thing missing from the plane is the top hatch and cockpit, test electronics and get all of your sub trim and transmitter settings set up the way you want them for maiden. The plane should now be airworthy and ready to test, aside from missing the top hatch.
8.) Top hatch: Install the two small attachment surfaces and Velcro strips in the nose box. If you haven't already, cut out the top hatch and bubble cockpit pieces. Assemble the cockpit by removing paper from and curving the top plate, and then gluing that to the sides. glue this directly along the center of the top hatch. Add opposite Velcro strips to the bottom of the hatch as indicated. You should now have a cockpit and top hatch which pop on and off just with Velcro! It is a good idea to actually glue down the Velcro strips, especially the ones on the nose box side, as they can start to peel.
Congratulations, your Floating Kidney should be ready to fly!
