FTFC24: Build-ruary by Spitifire76
Spitfire76
FTFC24: Build-ruary by Spitifire76 (Build skill: 3, Pilot skill 2)
My first time in this challenge. My build list is
Link to main challenge thread.
Spitfire76
FT-Build-ruary: Eclipson Go 1 Wolf Build by Spitfire76
Pictures
Plans - https://www.eclipson-airplanes.com/gö1wolf (free to download)
Reason for choosing this plane - wanted to see if this one is good to recommend to noobs to 3dprinted planes
Estimated build time
Detailed build log
How did the build go (1-simple, 5-complex)? 2
One of the simpler builds for a 3d printed plane as there are not so many parts to print
How well did it fly (1-easy, 5 hard)? 2
As its a powered glider doesn't need much throttle once its in the air.
Color scheme: Orange stripes.
Maiden Video: See detailed build log above
Summary, dos and don'ts: Pay attention to the throws especially the ailerons.
Spitfire76
FT-Build-ruary: Eclipson Model B XL Build by Spitfire76
Pictures
Plans - https://www.eclipson-airplanes.com/modelbxl (38 Euros)
Reason for choosing this plane - built their original Model B but prefer larger planes as they are easier to fly and easier to see.
Build times: Printing = 84.5 hours, Airframe assembly = TBD, Electronics installation = TBD
Detailed build log
Color scheme
Maiden Video
Spitfire76
FT-Build-ruary: 3dLabprint J35 Saab Draken Build by Spitfire76
Pictures
Plans - https://3dlabprint.com/shop/j35_draken/ ($20)
Reason for choosing this plane - It will be my first 3d printed EDF powered jet.
Build times: Printing = TBD, Airframe assembly = TBD, Electronics installation = TBD
Detailed build log
Color scheme
Maiden Video
Spitfire76
FT-Build-ruary: FT Long EZ Build by Spitfire76
replaces FT-Build-ruary: FT Slow Stick S250 Build by Spitfire76
Pictures
Plans - https://forum.flitetest.com/index.php?resources/ft-longez.37/
Reason for choosing this plane instead of the FT Slow Stick - Had problems finding the right diameter arrow shaft to fit the 3dprinted parts.
Detailed build log
Color scheme
Maiden Video
Foamforce
Cool! I built the Wolf with normal PLA. At first it flew just ok, but two adjustments made it fly great. Initially I had a SunnySky 2212-980kv with an 10x4.5SF and that felt a little underpowered. I switched to a SunnySky v3 (blue) 2216-1400kv with a 9x6. Now it feels powerful and fast with nearly unlimited vertical. The other important change I made was to use the aileron deflection recommendations from Eclipson. Initially I did 30 degrees up and down. With that, there was a disturbing amount of adverse yaw. When I switched to the 20 degrees up and 6 degrees down that get recommended, then it flew great!
In summary, I didn’t listen to their recommendations initially and it didn’t fly great. But then when I listened, it did much better. 😂
Spitfire76
Build-ruary challenge day 29 of 29
Never even got started on this build and the challenge ends today. I did get at least one plane built and flown though.
FoamyDM
Building Fool-Flying Noob
A deceptively simple challenge. I love the ambition you took on this year. 3D printing is considered by many to be ambitious undertaking to complete just one. Congratulations on successfully getting on complete and flying. It looks and flies great!
I always look forward to what you are working on.
