The polls have closed and the decision is in. The Bugatti lost out due to cost and I'm not about to ask a community based on being cheap for handouts. The subject for my build at the Flite Test Flight Fest 2015 will be the Sikorsky S-39. Its an interesting subject that has a great place in the history of aviation. I've never been particularly fond of the look but I love the history.
First thing to address is size. The plans I have are for a 76 inch wingspan. Too big? Too small? Having to transport this thing home from the event I have to say I'm not really willing to go bigger. At any size the wings will be hot wire cut from 2" pink insulation foam. Covering will be tissue and WBPU. Floats will be made from the same foam. Fuselage can go either way. Solid foam hot wire sections, or formers that are sheeted. Size will also dictate the size of motor and cell count. At 76 inch span the max prop size is 12 inches. Maybe a .46 size on 4S. Plans call for a .60 size motor but Mine will not be as heavy
Next is the issue of landing gear. I have to say that I do not do float planes. I have no place locally to really fly them. Landing gear will be fixed despite early indications that I would make them retract. Its just not worth the effort as I would only fly this off grass. It also makes waterproofing a non-issue.
I have sourced plastic parts for the dummy 9-cylinder radial and a plastic nacelle cover from Park Flyer plastics. With the majority of electronics going into the wing, I'll need access to them. I'll have to get creative to get the tail wheel servo wire connected. The main positive and negative battery lines will run down the fore struts for the wing. I'll use brass tubing and solder screw-down plates to secure them. The battery will then be in the fuselage. More than likely servos and their wires will be embedded into the wing. Rudder functionality still needs to be engineered. the 76 inch plan calls for booms of 28 inches long. A perfect candidate for carbon fiber arrow shafts. I'll build a box around them to get the right shape. Elevator control will run through one of them leaving the other for possible rudder control.
We have a looong time to develop a plan and I FULLY expect input and criticism from you all. If you have an idea or want to contribute anything, I need it! This is something that was asked for and I fully intend to deliver.
