Hello y’all this is Romby6 the original owner of this post hope all is well with you guys my account got banned for some reason a while ago so I have not been posting. I have completely re did the plane wirh some unique bumps along the way I have everything complete except the tune of the engine which I am trying to do now. The engine sounds beautiful but keeping it running is the only problem I can get it started but once I take the glow plug off it dies.
I suspect that you have lost compression OR the glowplug is running too cold, (possibly due to a degree of thermal insulating contamination.
You should try a new glowplug or even a hotter one, (i.e. 1.5V).
If that does not fix the issue and you do not wish to rebuild the engine to increase compression you could run a maintenance current through the glowplug by adding a battery, current limiting resister, and an alligator clip, (and wires of course). Change the battery frequently and disconnect when the motor is not to be run!
I would recommend the rebuild simply because compression rarely even improves with usage.
Have fun!
