General design and printing advice for an intermediate 3d printer guy?
Hey, was just wondering if anyone could point me to general advice for designing and printing RC aircraft parts.
Thanx
Edit: I look at this and realize that if I saw it I'd say "could you be a bit more specific?" So, I have a Lulzbot Taz6 that works great and I'd consider myself a bit beyond a rank beginner with it but far from an expert.
I also use Fusion 360 for a lot of different things and I'm about the same place. Not stumbling in the dark but certainly not where I could work for someone using it. You know, a reasonable amateur.
Anyway, I look at a lot of these FT designs and other RC designs and think, "this thing could be a lot nicer with just a couple of 3d printed parts".
If I get good with little parts,,,, who knows where it could lead?
So, any reference material or personal advice whether specific or general is much appreciated.
Thanx
Have you looked at Thingiverse and searched for Flitetest or FT airplane parts? There are quite a few posted out there that can be downloaded and printed.
#3
I have and I do my best to deconstruct what others have done but sometimes people have hard found good advice if you just ask. So I was/am asking.
And the interwebs are weird, sometimes I can ask something as a cast-off and get a hundred replies other times........ yeah, it's been months and you're the first, so thanx.
bracesport
I use 1mm PLA for my plane parts - others use thin wall PETG - I am yet to get tricky without build material, but that will be my next step - I use an ‘upbox’ printer that does the job pretty well. My DLG and even my Spitfire use 3D printed parts.
Regards.
#5
....... snip............
The Viggen nose you see in my avatar is exactly what you propose. The FT foam construction is great and actually looks surprisingly scale except trying to force foam board to form a pointed nose is a struggle. So I designed a 3D printed nose cone which is sacrifical just like the standard foam board nose. While I was at it, I included the intakes to clean up that area as well. I have made quite a few noses and countless motor mounts to replace the ubiquitous Flite Test power pod, something I never use.
For a simple firewall, I usually make the firewall itself 2mm thick with three top and bottom layers and a 40% or 50% infill. I print thin webs aft of the firewall which fit inside the typical square foam fuselage. Usually they're about .8mm thick and extend 5 or 10 mm aft of the firewall. I usually make a series of 2mm holes in these webs so that the hot glue will have something to grip. More often than not I print a very short (2mm) web extending back from the firewall which fits on the outside of the fuselage. You can see that feature in the rendering below. This particular firewall, an early design, is more complicated than necessary, but it gives you an idea of what I'm talking about. you can see how the inside and outside webs capture the front edge of a square foam fuselage and capture the vulnerable, unprotected raw foam edges. These days I would eliminate the X web in the center. When you crash, these firewalls never suffer damage. It's always the foam which fails, so you can go lighter than you might think when 3D printing firewalls.
Typically I make four bosses to accept 3mm motor mount bolts. I make undersized holes and run a 3mm tap through them and thread the screws directly into the plastic. I find that works better than printing the threads. Or, sometimes I print a feature to capture a 3mm nut on the aft end of the mounting screw boss.
Get familiar with the loft command and the shell command in Fusion 360. They will come in handy when making nose cones for EDF or prop-in-slot jet models. On simple nose cones, you can loft a solid and print it as a solid using Vase Mode to produce a very thin and light nose cone. Or you can shell the solid body and print using normal methods.
I recently made a Bloody Baron nose. It connects to the standard square fuselage just forward of the wing leading edge. I made a loft from that square cross section to a round firewall. The part looks like this:
Then I designed a Fokker DVIII style cowling which is printed separately and glued on after the motor is screwed in place. Those rails extending aft support a foam "shelf" which holds the battery and ESC.
For best results, give some thought about the print orientation EARLY in the design process. I have a tendency to make my parts very strong. Consiquently, they are over built and heavier than necessary. I have overcome that bad tendency for the most part, but I'm always fighting the urge to add another web or another fillet. Try to build hybrid parts lighter than you think is appropriate. A horrible crash always results in a pile of crumpled foam and a perfectly intact plastic part.
I use a .4mm nozzle with .2mm layer height. When I draw a thin part and think that a 1mm thickness would be OK, I now specify a horizontal distance of .8mm or sometimes .4mm. In the vertical, rather than go with 1mm, I specify .6mm when I can. Keep fighting against making parts too strong (heavy).
Of course things like control horns, tail skids, wing tips, servo arm extensions, arrow shaft joiners, battery trays, and stuff like that are easy enough if you give them a bit of thought. Again, lighter is better.
I print all my parts in a "tough" PLA. I find eSUN Pla Plus (also called Pla Pro) to be a very good product. It's much less brittle than ordinary PLA. I print it at 235 degrees for ordinary parts and 245 degrees for single wall parts. It gives great layer-to-layer adhesion and a good surface finish. It's available in many colors at a reasonable price from Amazon.
#6
A lot to deconstruct here, thanks much!
#7
Build the aircraft before you design stuff in CAD. When I add more detail to a plane with 3d printing I always build it first and take dimensions from it by hand. This is very lazy, but sometimes I will cut the under-cambered part of a wingtip off and trace the wing chord on to a piece of paper. Then I will scan that paper and put the image in Inventor or whatever CAD device. This is an easy way to make wingtips for a faster plane. If you ever want to replace a foam piece with a 3d printed piece I always just cut the piece out of the model and take some dimensions.
