Glenfilthie
I just love these big multirotors the FT gang does. A year or two ago I bought one of those Bat Bone kits and built a V Tail out of it - and it was more fun than a barrel of monkeys! I got really good at flying line of sight and got so I was going out in fairly stiff wind - and I could still cut a rug with it. One day I had a run-away and I lost it in the woods and I was one broken hearted old fart!
(It was all my fault; I got a swollen head and the aviation gods punished me for my arrogance!)
So I finally got over it and ordered the Y6 kit and electronics from the boys and I am so close to flying this bird - but for a few maddening obstacles. Cranial Rectosis got me straightened out on the wiring. When I plug the Y6 into the computer, all the inputs track as they should on the right channels. The motors all spin the right way... but the darn thing just can't seem to get off the ground!
I have a few concerns or issues for the gurus - your two cents is sincerely appreciated if you care to comment.
1. Loop time - this may or may not be an issue according to what I've seen on the new Naze 32 Rev 6. I tried to set it to 1500 as per Josh's video... but the board will not accept the value even after saving. It is "stuck" at around 1000. Some of the guys are saying the new boards and ESC's can handle that - if you've heard different I would like to hear from you!
2. Could the refusal to take off be the battery weight? I wanted a great big 3 cell in hopes of keeping the bird a little over on the slow side. I only charged it up to 3.8V for a quick hover test...would more voltage help it get off the ground? (I'm grabbing at straws here...)
3. The coaxial props have me foozbarred. All the motors are spinning in the right direction. The props are the standard EMAX ones that come with the recommended Flite Test Power Pack for their Y6. But they just don't make sense to me.
The top prop spins clockwise and you can see that it is pitched to push the air downward. The bottom prop will spin counterclockwise... but the only way to get it to push air down for thrust, is to mount it so that the thinner trailing edge 'leads'. Am I having a brain fart?
Any suggestions or remedies at this point are sincerely appreciated. I would really like to get in the air again...
