suggestions pls
JetCrafts Active member Aug 27, 2022 #3 Ligbaer said: su-47 berkut Click to expand... na already made one like that
JetCrafts Active member Aug 29, 2022 #5 Ligbaer said: do a a330 Click to expand... to simple of a design
JetCrafts Active member Aug 30, 2022 #7 Ligbaer said: mahoney sorerecess Click to expand... too simple and staggerwing ,s to slow
Aslansmonkey Well-known member Aug 30, 2022 #8 Seems to me you have some specific unspoken requirements because you're shooting down a bunch of suggestions here. Perhaps if you clarify better exactly what it is your looking for you'd get more help.
Matthewdupreez Legendary member Aug 30, 2022 #9 JetCrafts said: suggestions pls Click to expand... High wing trainer
Ligbaer 50 Percenter Aug 30, 2022 #10 Aslansmonkey said: Seems to me you have some specific unspoken requirements because you're shooting down a bunch of suggestions here. Perhaps if you clarify better exactly what it i s your looking for you'd get more help. Click to expand... i agree a a330 ez pack would be cool tho
JetCrafts Active member Aug 30, 2022 #11 Matthewdupreez said: High wing trainer Click to expand... done ,done'
JetCrafts Active member Aug 31, 2022 #13 Ligbaer said: autogyro Click to expand... i m an idiot with using gears
Matthewdupreez Legendary member Aug 31, 2022 #14 JetCrafts said: done ,done' Click to expand... Plans??
JetCrafts Active member Aug 31, 2022 #15 Ligbaer said: autogyro Click to expand... i m an idiot with using gears
JetCrafts Active member Aug 31, 2022 #16 Matthewdupreez said: Plans?? Click to expand... youre talking to a 14 year old without a scanner and doesn't know how to make any
Ligbaer 50 Percenter Aug 31, 2022 #17 JetCrafts said: i m an idiot with using gears Click to expand... straw skewer and foam not that hard
JetCrafts Active member Sep 1, 2022 #18 Ligbaer said: straw skewer and foam not that hard Click to expand... how work
ennobee Member Sep 5, 2022 #19 JetCrafts said: suggestions pls Click to expand... So if I get it right, you want a small slowflyer, possibly indoor using the EZ-stem two differential engine setup for propulsion and control?
FlyerInStyle Elite member Sep 5, 2022 #20 JetCrafts said: how work Click to expand... you just make a hole in foam stick a skewer through and you have afreely rotating blade. then you put on some how glue as a stopper and you have a simple rotating mechanism look at the twin twirl build video by flitetest
