Spitfire76
Maiden of the EZ Jet ME262 went well, amazing how well it flies. Only thing is the battery came out after a couple of flights and messed up the CG. There really needs a better way to secure the battery. Also is it really necessary to remove the paper on these planes now that we have V2 of the power pack ? It really makes the planes very fragile.
AIRFORGE
Make It Fly!
I always leave the paper on.
AgentC
Does anyone know if the battery on the EZ power pack V2 is protected from being over discharged ? Only I would hope that it cuts power if it detects the battery is getting close to the 3.3v mark.
On another note I checked and it does have a failsafe mechanism as the throttle is cut if signal is lost.
The batteries do come with overcharge protection. Good to know about the failsafe on the throttle!
AIRFORGE
Make It Fly!
I just watched the Flite Crew's latest YouTube vid and I think I'm going to build an EZ Air Boat this weekend.
They're a blast! started building them about 3 or 4 months ago and I'm working on my 4th one, now. They can be pretty fast for something so small.
AgentC
I made a few snow skimmers out of foam trays, then decided to make a foam board version (PDF attached). Works great indoors and on smooth ice and snow. Bumpy snow makes it a bit tricky, but still a hoot...
  • EZ Skimmer v1.1 (Beta).pdf
luvmy40
So, with the air boats, we are not worried about the FC function of the EZ control board so orientation is not important, correct?
On second thought; we would still need forward to be "forward so the left/right stabilization doesn't think it is reacting to outside influence when responding to rudder input?
AIRFORGE
Make It Fly!
Correct orientation is still needed.
Spitfire76
Decided to try the EZ Intruder but will need to change the V2 power pack motors from pushers to tractors. Do I just swap the props and if so what's the best way to remove them ?
AgentC
Same as a v1's for prop rotation. The only issue is that the props are a bit more difficult to remove, and there is no prop removal tool now. Pinch and pull gently, but with some force. Good luck!
L Edge
If you can find something plastic like this and shaped very thin at the bottom, it works real well in removing the prop. This tool was in a battery changing unit (Apple) kit and it serves the purpose. Make sure you are holding the motor's casing unit while removing.
Thorondor
I have the transmitter from the v1 pack, can I just buy the add-on pack and bind to it, or did the protocol change? I also have a QX7 if there's a way to get that to work.
Foamforce
You can apparently use a 4in1 module with a QX7, so you ought to be able to use that. The 4in1 is great!
AIRFORGE
Make It Fly!
I can't find it, but in one of the EZ vids I think Josh says it will work.
If you have a 4in1, the protocol is GD00X GDV2.
