Beveled the rudder/elevator and added slots for hinges, as well as test-fit everything to make sure I didn't screw anything up. The plan and manual call for Monokote hinges, and the first thing everyone should know about monokote hinges is that you should never ever use them under any circumstances, because they suck. And also sometimes randomly cause your control surfaces to leave the airplane which can have undesirable effects on how the airplane flies.
I also want the stick-built look of the rudder for the elevator but sadly it's just a piece of solid trailing edge stock (what the hell Carl Goldberg????) I think I'll make something custom...
The inboard halves of both wings are also pretty much done, they only need sheeting applied to the top, but that gets done when they get joined anyway. The instructions say you should build the right inboard half, followed by the outboard half, but after some review of the building instructions I determined that doing it this way won't pose any significant problems. The reason I'm doing it is to keep the plan as intact as possible, so if I end up doing some nonsense while flying that means I have to rebuild the wing, I have the plans available. I'm also not going to bother with building the detachable wingtips since according to some people they have a bad habit of failing in flight. Neither will I be making the tail detachable, since I measured everything out and the complete wing will fit in my Golf, somehow, and the fuse/tail are smaller than that even when assembled together. At this point all a detachable tail would add is more weight and an extra point of failure.
I should stop finishing things at 2 am. Then maybe the pictures will be better.
