Hello everyone:
I am planning a high powered, high speed flying wing build for LOS flying. Its going to be based loosely on the Versa wing, with a larger wingspan (roughly 1.5m) and a cutout in the rear to move the motor forward for CG purposes. Power system is as follows:
Motor: Propdrive 3536-1800
80A ESC
8x6 prop (maybe bigger if it doesn't pull too many amps)
5000 mAh 3S LiPo
As the plan is to build a flying wing, it will obviously use elevons for control. I am brainstorming using 2 servos per control surface to make sure that the servos can handle the forces at high speed. If anyone has used a similar setup, I would like to hear about it. I'm wondering if it would make more sense to have 2 elevons on each side with their own servo, or two servos driving each large elevon. Or maybe the best solution would be to get something larger than the tower pro 9g servos that I've used on all my other builds. Input and feedback is welcome.
The other question I have revolves around the battery. V1 of this wing used two 1500 mAh LiPos in parallel for two reasons: First of all, 2x35C gave me enough sustainable current to feed this motor, and secondly, the smaller 1500s could be moved far enough forward to balance out the wing. I would like to avoid paralleling the batteries if possible and switch to a larger 5000 pack. It should help with balance and provide some more flight time. If for some reason I can't get the 5000 to fit, is it possible to use 2 parallel harnesses to hook 3 batteries together? Two would be on one harness, and then that harness would connect to another harness with a third battery on it. Would that work or would it cause problems with the third battery? Again, anyone with more experience is welcome to chime in.
@Hai-Lee I'm tagging you because I feel like you know the most about some of this stuff and you have a lot of building experience.
80A ESC
5000 mAh 3S LiPo
