GoPro & Easystar, nose blocking the view
mipi
I'm trying to mount GoPro (version 1) on Easystar but planes nose is blocking the view.
I want to record flight without any visible plane parts.
There are few possibilities,
-lift camera higher (blocks air flow to propeller, breaks easily if crashed)
-move camera forward (COG is way off)
-cut off piece on nose (earodynamic issues, weakens the frame)
Has anyone found solution for this?
especially pictures would be helpful.
zev
lumpy member
#2
can you move the camera forward and move the battery back? also, you could try sticking the camera on the bottom and pointing it down a bit, but the you would need to add landing gear, or land on your gopro.
Bolvon72
My solution on the Bixler was to mount a number of squares of foam glued together. It dampens vibration nice as well. I simply added until it was high enough to get over the nose. I do use a wingcam which is more aerodynamic than the gopro and easier to rubber band down for security, but it's worth a look.
