Gyroscopic frustration
Brian fred carr
Site Moderator
If there is an experienced chopper man out there who can help me i will be very grateful,,,,,I am having a real nightmare setting up the HK 401b gyro on a 450 clone..i have looked on the tube and there is nothing definitive I can use. If I fly without the gyro fitted i can just about get it off the ground but the constant rudder inputs to keep it straight makes throttle management almost impossible...if i fly it with the gyro it just spins one way and when i input to correct it just spins in the opposite direction....I am using a 9x....thanks in advance
nibnobsam
I like big leccy planes
Sounds like it's reversed, there should be a small switch on the top which you need to set to reverse using a small screw driver.
