There are a number of ways to mount the board, based on what you have on hand. Usually the foam is adhesive on both sides like this stuff:http://www.hobbyking.com/hobbyking/...oam_double_sided_tape_10x5inch_4mm_thick.html
You can also use screws, zip ties, velcro, or even combinations of these for mounting. Just make sure you try to isolate the board from vibrations but that it's not coming loose during flight.
One of our members runs a zip tie down through holes in the board and through holes drilled in the foam and frame and uses the head off an extra tie to secure
