accelangel
accelangel
First I would like to say this is my first post. I have made the formatting as organized as I can, hope you enjoy.
I recently bought all these components with the intention of building and flying the Habu 2.
I will also be using some equipment I already have.
When I decided to invest money into this, I had the intention of trying to fly faster than any plane I have owned in the past. For this reason I bought the BL32 motor since it could handle 6s voltage over the BL15 motor that could only handle 4s voltage. Link to BL15 motor: http://bit.ly/1O2HJrC
Looking back at this decision, I see how naive I may have been. I didn't bother to crunch the numbers before I made the purchase and it may have costed me.
Calculations
RPM
KV of motor multiplied by the volage of a full charge 4s and 6s battery for each respective motor. 4.2v per full charge cell x4/x6.
BL15 Motor 3600KV x 16.8V = 60480 rpm
BL32 Motor 2150KV x 25.2 = 54180 rpm
Wattage
I don't have the BL15 motor, thankfully E-Flite has the current draw of the BL15 motor on the same fan that I am using on it's website, it's 46 amps.
BL15 Motor 46 amps x 16.8V = 772 Watts
This current draw for the BL32 is my own measurement I took
BL32 Motor 32 amps x 25.2V = 806 Watts
(Both these measurements are using the same fan unit)
Conclusion
So does this ultimately mean that I would have been faster with the 4s BL15 setup since I have lower rpm with the 6s setup?
Will I even be fast? According to this source http://bit.ly/1Xxl8hl, I need 180 Watts/Pound for the higher performance an EDF jet needs. It also says 200 Watts/Pound will give me unlimited ballistic performance.
The weight of my model is 1.6kg or 3.52 pounds. With this simply do 806 Watts / 3.52lb = 228 Watts/Pound
This seems to indicate my model will still have great performance. Either way, I will fly it and measure the speed. If it is not satisfactory I can still change the fan to something with more blades.
Right now my fan has 5 blades and I'm only drawing 32 amps. My ESC is rated for 60, so I can probably go for 10 blades and just push my ESC harder than 32 amps. That would be the cheapest way to increase my performance.
If you have made it this far, thanks for reading. If anyone has any other ideas to help me increase performance or if anyone can already look at my numbers and know I will be fast, please let me know. I'm looking for at least 120 mph.
Thank you for reading my first post.
- http://bit.ly/1l6JVrE Bare Airframe: Habu 2
- http://bit.ly/1Nn7S3I Delta-V 15 69mm Electric Ducted Fan
- http://bit.ly/1MVLnG0 BL32 Ducted Fan Motor, 2150Kv
- http://bit.ly/1Nn84A2 60-Amp Pro Switch-Mode BEC Brushless ESC (V2)
- http://bit.ly/1YGGF4n Hitec HS-65MG Mighty Metal Gear Feather Micro Servo - Rudder and Elavator
- http://bit.ly/1SvO0Qs Hitec HS-65HB Mighty Karbonite Feather Micro Servo - Aileron and Nose Wheel
- http://bit.ly/1HG33qp Hitec HS-55 Economy Feather Sub Micro Servo - Flaps
- http://bit.ly/1Xx1Pon - DX6i DSM2 Radio
- http://bit.ly/1l6Lzt6 - AR610 6-Channel DSMX Aircraft Receiver
- http://bit.ly/1luGUB0 - Hobby People 11.1V 2200mAh (3S) 30C LiPo Battery(I will be using two of these with a series connector to have 6s power system)
Calculations
RPM
Wattage
Conclusion
