flatpackair
Greetings,
I hoping someone can help. I've been flying DTFB airplanes for about 3 years, mostly in urban areas (in parks and abandoned lots) near my house. My first radio was the flysky CT6B which worked great most of the time, however i started to notice signal dropouts in certain places at the parks I fly. I took that radio apart and found the antenna connection had come undone from the board, I re-soldered it and flew a bit more but still had intermittent problems. I then upgraded to the Turingy 9x, it in general has been good, but I still have glitches at the same points in the sky that I did before.
My Setup
Turnigy 9X (stock w/ stock receiver)
Fatshark 250mw video transmitter (stock dipole antenna)
Turnigy cheapo servos
30amp red brick esc (most commonly used)
Variety of brushless motors
I have the video transmitter spaced away from the Rx and the ESC as far as possible from the Rx as well. The problem occurs with or without the FPV gear.
The Problem
The fields I fly aren't that big, about the size of a soccer field, so I am never very far away. I also follow the FAA guidelines for altitude so 400ft is the maximum, but I rarely go over 200'. The fields are typically lined with houses or buildings that I fly near but not over. The problem will occur at the same point in the sky (or near ground) every time as I fly around, and those points haven't changed in years even with many different airplanes and two different radios. When it happens I will lose all control for 1-2 seconds.
My Question
Is this something normal for flying in urban areas on the 2.4ghz band? This is my biggest question, I have looked into possible issues with the BEC becoming overloaded and shutting down, my antenna position and so on fruitlessly. What are the possible solutions, should I go to 433mhz, change antennas or change my stock 2.4 module? Thank you guys for any help you can give me, its frustrating when my 5.8Ghz video signal on stock dipole antennas is much more robust than my 2.4Ghz for control.
My Setup
The Problem
My Question
