HELP MY CHARGER ISNT WORKING
Salill
Hey all. So I got this charger recently and it’s been showing this screen since I have ever tuned it on. What dose this mRNA and how can I fix it thanks. Btw it’s a Lipro charger b6 just took it the cover.
quorneng
I have two, one mains powered. Never had that screen.
My immediate suggestion is to check that the power supply you are using is rectified and within the voltage range. Then like all things electric test the supply on another B6. If that works then you know your B6 is faulty. To fix you would need serious test equipment and knowledge.
I replaced my "failed" B6 and still have it I just can't bring myself to chuck it out.
Salill
Hey man. I used a car battery that has 12 volts (that’s what is recommended voltage for the charger) and the screen is still there so voltage seems to not be the issue
Shurik-1960
This is the first time I have encountered such a malfunction. Alas, NO ONE will be able to give you advice, except to contact specialists in the repair of radio equipment. I could watch and repair it for free (if the screen matrix is working properly), but I live in Moscow and sending it back and forth will cost like a new charge. I can give you some advice: take a needle and a large magnifying glass and carefully look at all the legs that go to the monitor.I think you'll find a torn monitor leg.
