Help Please
Nightkrawlrr
Hi everyone. sorry to bug you all but i need some help. I have built this 210. everything is wired and passes all my tests i just cant get the board to arm is what i think the problem is but you all have way more experience than i do. i posted a video below. Any help would be appreciated. thanks so so so so much.
https://youtu.be/1UdRwWl8-50
fc: spf3 version: 3.0.1betaflight
oneshot 125 bl heli escs
emax 2205 2300kv
all contols from transmitter are received and register on the reveiver tab in betaflight but will not physically spin the motors.
if there is anymore info you need please ask
Imzzaudae
Sounds like the board is seeing throttle above zero at startup. Move the throttle trim all the way down as far as it will go and try again.
This is a safety feature. See what happens.
paulshort
Ok. First use the subtrims on your radio to adjust all the channels until they read 1500 + - 1-3
Then adjust the endpoints in your radio (or travel adjust) until the channels all move from 1000 to 2000
another point is that it will not arm unless the flight controller is level (In the video its on a 45 degree angle)
Paul
