I had a very fast unscheduled landing with my sport cub and I’m having some issues. The plane wants to nose down a lot to the point where I have to constantly hold about 20-30% down pressure for it to track straight. However with the flaps in full deflection the plane flies straight enough. The plane doesn’t want to do aerobatics at all. It’ll just stall very aggressively. At lower speeds the plane gets quite unstable and makes low speed scale flying a hassle. For the past 3 days I’ve been tweaking everything. I’ve checked the thrust angle, I’ve checked the main wing, I steamed the ailerons and flaps to make them as straight and flush as possible. The tail feathers are trimmed as perfect as possible. As well as balancing as perfect as possible. I’ve even tried slightly tail heavy and nose heavy. Both make very little to no difference. I also thought it could have been the thrust angle so I took everything out of the fuse and dipped it into boiling water to get the deformations out of it. I checked the prop shaft and it’s fine. All of that and it still does the exact same thing. I have no idea if the wing or the part of the fuse where the wing mounts to is warped or what. And since I’m constantly holding pressure on the elevator as3x doesn’t kick in so it makes it sketchy to fly in wind. Granted 40mph wind is nothing to me so as3x isn’t quite needed. But I do enjoy having it when I’m just cruising around. This whole ordeal is quite frustrating because the plane looks like there is nothing wrong with it. The undercarriage also bent a lot from the sudden stop so it doesn’t quite sit correctly. It still works nonetheless. Any help would be greatly appreciated
