I took the Bonanza out again today and it was an absolute dog. Now I realize that I grabbed a nearly dead pack so my flite was short and not very powerful. Or should I saw my flites. The entire time was spent launching th plane, mushing through a depressing stall till landing not so gracefull, then going to pick up the plane and repeat. I got it in the air one time and it felt alright, but I believe my thrust angle is too far down after my nose repair. Being on the throttle pushes the nose down a lot. That's probably why I couldn;t get off the ground.
Anyway, I crashed it several times in a variety of ways. Nose ins, tip strikes, even a cartwheel. The plane is still in one piece believe it or not (granted all of the crashes were failed launches, so low speed).
I'm going to try to fix her up, but my mind is already focused on V2.
Here are the improvements I need to implement:
-All of the fit and finish flaw of V1 need to be fixed and updated in CAD.
-A turtle deck pattern needs to be made and added to CAD.
-Ailerons need to be slightly bigger.
-Wing needs to removable if desired, like the FT Spitfire. Otherwise the plane will not fit in my car without bending wingtips.
-Front end needs to be beefed up considerably, primarily the Power Pod mounting area.
-I have plans for shapely lower cowl panel like the FT Mustang. The cowl must be sturdy enough to mount a retractable nose gear.
I will release V2 plans as soon as I finish them so you don't have to wait for me to build it. I'm confident in the basic design, these tweaks will just make it better.
