Hobby King Buddy Codes
colorex
Rotor Riot!
It's a way to get discounts on some products. Consists of two parts:
First, person A buys something - say a DT-750 motor. When the order is paid, user A signs in, goes to his account, and click's on the "CHECK" button just under their name.
Andre Elb (colorex)
Customer Type: Platinum Member
Orders: 14 CHECK
Your Wish List has 9 items
Account settings & tools
Warranty Codes
Then click on the latest order's VIEW button (to the left).
[TD="colspan: 3"]
[/TD]
[TD="colspan: 2"][/TD]
[TD="colspan: 2"]Shipment[/TD]
International (Registered) Air Mail 0 - 100g $3.99
[TD="colspan: 2"]Taxes[/TD]
$0.00
To the right of where it says RESERVED, a blue icon will show up, indicating that a buddycode is available. clicking on it will bring up a window with a long link that looks like this:
Person A can post this link to a forum, or to a website like RC International, so person B can use it to get the same product a bit cheaper.
Person B has to login before using a buddycode. Log in, and click on the buddy code link. the item page will appear, and if the buddy code is valid still (eg. hasn't been used more than three times), then the price will show up lower, and with a * sign indicating a discount.
When you click "Add to cart" the item will be added at the discounted price. When Person B buys a product with a buddy code (reduced price) then the blue buddy code icon will not show up in their order like Person A.
Two months ago were the glorious days when you could use as many buddycode products as you wanted. But now orders are limited to 2 buddycodes.
Several items have substantial price reductions ($5 on Turnigy Basic 25Amp ESC's for example), so it's worth the hassle.
So what's the catch for person A? When someone purchases an item with the buddy code, Person A receives a small amount of cash back into his account as store credit available for use in the next purchase. Discount for both A and B.
Sorry for the short explanation.
jd7792
#3
......Sorry for the short explanation.[/QUOTE]
Thanks for the explanation! Long or short I now have it all sorted.
bseal
#5
Turnigy Receiver Controlled Switch http://www.hobbyking.com/buddy.asp?code=95EBF9F5-9708-441A-A2DD-5F06AF1D4EF8
Turnigy High Density R/C LED Flexible Strip- http://www.hobbyking.com/buddy.asp?code=BB62C537-B714-425D-9D40-467872E2BA72
Turnigy 9X LCD Backlight Kit - Blue (DIY) http://www.hobbyking.com/buddy.asp?code=956426E0-049C-4843-B2CC-0BD434BF59DB
Carbon Fiber Tube (hollow) 3x2x750mm http://www.hobbyking.com/buddy.asp?code=6D502449-5368-4FE7-ACAC-2241B041E28B
Strong Rare-Earth Button Magnets (10pcs/set) http://www.hobbyking.com/buddy.asp?code=699871B8-F028-47BF-80EE-E9843DAF9EFE
Turnigy Aerodrive SK3 2826 Series Replacemen http://www.hobbyking.com/buddy.asp?code=AFABE810-6A50-4F27-9268-1FE546922C72
TURNIGY Plush 40amp Speed Controller http://www.hobbyking.com/buddy.asp?code=52907E33-416E-4FD8-9433-444417114A4A
Polyester Hook & Loop Velcro V-STRONG (1mtr) http://www.hobbyking.com/buddy.asp?code=577C6017-E265-44DD-B9F0-45C9197409C1
Carbon Fiber Square Tube 750x6mm http://www.hobbyking.com/buddy.asp?code=65AB989F-AC83-4D3A-98E5-4ACEA3A19A59
SF E-Prop 7x4 / 178x102mm w/ Adapters Black http://www.hobbyking.com/buddy.asp?code=8AA5F9FA-22F1-437B-AAD9-79B09794222D
Turnigy High Density R/C LED Flexible Strip- http://www.hobbyking.com/buddy.asp?code=9C209E52-AAF0-4307-AF09-73B962C65AD3
Turnigy High Density R/C LED Flexible Strip- http://www.hobbyking.com/buddy.asp?code=30EEF344-37E7-4C6C-84CA-6EFD608F2B9F
Turnigy High Density R/C LED Flexible Strip- http://www.hobbyking.com/buddy.asp?code=ACAFB249-9297-4DA0-8ADD-1F783A878B07
Turnigy nano-tech 460mah 2S 25~40C Lipo Pack http://www.hobbyking.com/buddy.asp?code=D86404E4-1504-4FDF-903D-F868DE49B447
Pivot & Round Hinges 2x33 (10pcs) http://www.hobbyking.com/buddy.asp?code=E3117A25-A8F3-4FDE-9AA7-E9D157CA713A
Linkage Stopper M3x2xL11.2mm (10pcs/set) http://www.hobbyking.com/buddy.asp?code=81DA2696-00B2-4260-A318-B252479D893A
Turnigy 9X 2.4GHz 8Ch Receiver (V2) http://www.hobbyking.com/buddy.asp?code=0E24AA0A-F385-45C6-98C9-F0395CAE90DB
Pin Horn 9x13 (10pcs) http://www.hobbyking.com/buddy.asp?code=819ACA98-0656-465F-AB60-CD31576E951D
AC Hinge Sheet 180mmx140mmx0.3mm http://www.hobbyking.com/buddy.asp?code=8672B1C8-4270-4F10-9DD8-15450222B052
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr) http://www.hobbyking.com/buddy.asp?code=38AE9FA2-DCA8-40FD-AFD7-11E6ED5092D6
Turnigy 2mm Heat Shrink Tube - RED (1mtr) http://www.hobbyking.com/buddy.asp?code=BB24EA09-5784-4A5F-8E98-4FE48F43D215
#15
Hope this works... These are my fresh buddy codes just posted on rcsearch:
All my buddy-codes on RCSearch.info
Turnigy Pure-Silicone Wire 14AWG (1mtr) RED (USA warehouse)
$0.92* (buddy price -39%, -$0.59)
Turnigy Pure-Silicone Wire 14AWG (1mtr) BLACK (USA warehouse)
3.5mm 3 wire Bullet-connector for motor (5pairs/bag) (USA warehouse)
$4.41*
Alloy Clevis for Non Threaded 2mm Control Rod (USA Warehouse)
$0.64* (buddy price -19%, -$0.15)
TURNIGY TRUST 45A SBEC Brushless Speed Controller (USA Warehouse)
$17.20* (buddy price -6%, -$1.13)
Hobby King 2.4Ghz 6Ch Tx USB Cable (USA warehouse)
$2.68* (buddy price -14%, -$0.44)
Turnigy TGY-50090M Metal Gear 9g Analog Servo (USA Warehouse)
$4.85* (buddy price -3%, -$0.16)
Turnigy nano-tech 950mah 3S 25~50C Lipo Pack (USA Warehouse)
$7.52* (buddy price -24%, -$2.35)
Slow Fly Electric Prop 8045R SF (4 pc) (USA Warehouse)
$2.26* (buddy price -13%, -$0.34)
Hobbyking 105W 15V/7A Switching DC Power Supply (USA Warehouse)
$12.67* (buddy price -12%, -$1.67)
Hobby King 2.4Ghz 6Ch Tx & Rx V2 - Mode 2 (USA Warehouse)
$27.20* (buddy price -9%, -$2.79)
Long Prop adapter w/ Alu Cone 3mm motor shaft (Grub Screw Type) (USA Warehouse)
$1.74*
Turnigy Trust SBEC Programming Card (USA Warehouse)
$2.41* (buddy price -36%, -$1.35)
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories (USA Warehouse)
$22.87* (buddy price -5%, -$1.2)
Z-bend Pliers. Heavy Duty 90deg up to 1/16 (USA Warehouse)
$5.58* (buddy price -19%, -$1.31)
Durafly Zephyr 1533mm - Replacement Control Horn/ Pushrod Keeper (USA Warehouse)
$3.78* (buddy price -24%, -$1.18)
MrGravey
#17
No one has used this in a while but I just placed another order so I thought I would share.
Turnigy Plush 25amp ESC (US warehouse) $1.84 discount
http://www.hobbyking.com/buddy.asp?code=D98954F9-DB4B-464A-A64F-9828B10F7A2C
Turnigy Plush 40amp ESC (US warehouse) $4.04 discount
http://www.hobbyking.com/buddy.asp?code=1A134A20-1C43-429A-86DF-ECC41C454AE3
Turnigy ESC programmer *For the above ESCs (US Warehouse) $3.02 dicount which is about half price
http://www.hobbyking.com/buddy.asp?code=9939641D-CEBB-40CE-B6D8-BE417BA405E5
From the looks of it keeping this thread going and coming to it first could save a ton of cash for all involved.
