bhursey
The Geeky Pilot
Haha, you know the designer? Ask him if he remembers what the dihedral angle is supposed to be. I found some plans for the low wing skimmer, and they said raise a wingtip up 7 inches. The two look the same, so that's what I went with for the dihedral gauge.
This build should be really simple, though it's hard to beat a Dart for simplicity. If you build this one, start with the wing first, and then make a test section of foam for the wing to set into. I think the cutout I have on the fuse now will be close, but you never know until you build the wing.
I don't have time to build or test this right now, as I'm swamped with other projects, that's why I included the CAD file. So you can tweak anything that needs adjusting.
Yah my skimmer plans say 7 inches. it says use dihedral gage to align the inside ribs.. However it say son the plans "Raise one wing tip 7 inches when joining panels"
Fuselage looks around 26 3/4 inches long but and under the wing the width of the fuse is 1 3/4th inch.. front its it tapers to the back..
