This is a homemade 3d plane I built last week that fly’s well.
Setup
Ar6110 e
4 x tower pro 9 gram
thunderbird 9
turnigy 2730 -1500
7x6 apc
dynamic engineering park bec
E-flight 3 cell 450 mah 25 c
The plane weighs all up 286 g
740 mm long
710 mm wide
The plane flies great in all attitudes, it has a little bit of coupling in knife edge because of wrong place meant of battery. It was a little lacking in power, but I’m acquiring a gws 8x4.3 in the next few days which will give it greater static thrust, and I’m going to try out 3 and 5 gram servos because I know the current ones are a little over powered.
In the first flight it held high alpha rolls, hover, snap rolls, flat spins(inverted, normal, and knife edge), but in knife edge it rolled to level out.
i crashed it on a inverted flat spin, the wing tip touched the grass and snapped the tail (which was only half as strong as it should due to missing the top foam piece).
I’ll see about re building it Wednesday when my new prop comes in and posting video.
