sierra_bravo
Well I was looking in my shed for some metal rods for a landing gear and in a corner of the shed I see a gas Home-lite leaf blower with a 26CC engine. I didn't test the engine because the only thing going threw my head was "well got to take this engine out of it's plastic cage" and so I did pull it out and cleaned it up a bit and also repainted the muffler but I dont know if it will run. I tested the spark plug and it does work. The rubber part of the primer bulb broke so I know I have to replace that and was thinking about this kit to replace the bulb and some of the fuel line. The carburetor will open and close smoothly but I dont think it will work for a RC engine. I dont know alot about small gas engines but I am pretty sure the piston has compression. The gasket for the crank shaft has to be replaced and the spinning part (which I think is called the fly wheel) spins smoothly. My goal with engine is to get it working to put in a SPAD 1/5 scale piper J-3 cub and to take it to a AMA event at my field. The event is August 15th which gives me around 50 days to get the motor running, build the plane, and get it to fly.
So since I'm 13 and dont have alot of experience(nor money)with gas engines I need some help on what I should do to get this motor running. My first question is how can I test if the engine will run. Should I just reconnect the fuel tank fill it with some gas and try it that way or it there some other way.
Thanks
-sam
Thanks
-sam
