Team_Monkey
OK, that's a long shaft, you will need a regular long shaft style prop adapter for that. If you tried to swing a prop that far away from the engine it would vibrate itself apart, don't do it. The prop adapter we came up with is only for low power, short shaft engines.
You may want to contact JAG about if they have a long shaft adapter for that engine, contact av8tor about if he has an adapter or kill the deal and find a short shaft engine. Depends on where you want to spend money.
As for plans, that's too easy. You could take the regular Corocub plans and scale them up from 76" span to 85" span. Or build it the stock size except reinforce the nose and paint the windows instead of cutting them.
You inspred me so I made a deal to pickup another 25cc homie on Monday.
