Kevin Hallaway
Senior member
Hi I have just received a Flite Test Kraken kit, quite expensive by the time it comes to UK with post and taxes but it is a BIG model!
I now have a problem in that the FT recommended glue gun is 110volts while in the UK the juice comes at 240volts. I can find similar wattage guns that work at 240 volts but these use 12.0mm glue sticks rather than the 12.7mm sticks that come from FT. Does anyone know what the specification or description or make of the FT glue sticks is so that I can try to fine a UK equivalent? The alternative would be to get the FT recommended gun and glue stick and use a suitable transformer but that is getting rather expensive.
Many thanks
Kevin
Many thanks
Kevin
