i have unfortunately nose dived my plane while learning a few times and my power pod has broken (I added some support before flying, so it was a little easier to insert the skewers). I will attach images below. in the thrid image you can see how bent the pod is. in the 4th the pins are in to hold it in place but you can't see then, in the last image you will see the supports i added and how bad the rips are.
what would people suggest to fix this?
