I bought the EMax 2213-935 motor from the FT Power Pack B but I broke the prop that it came with so I went back to the hobby store I bought it from and they said that don't have props with the "key" that the EMax motor and prop have. You can sort of see it in the picture of the broken prop, two of the sides are flattened and the base of the motor shaft has a matching shape.
I bought an equivalent prop and they recommended using a lock nut on the end of the shaft, but I really like the conical (non locking) nut that came with the motor and was wondering if I could use it again? Or should I definitely be using the lock nut since this prop sits above the keyed part of the motor shaft as opposed to the EMax prop that went all the way down?
Thanks!
Thanks!
