Peace and love to all...
Need some help here please.
I've been trying to brainstorm a method of strengthening my enlarged versa wing I use for fpv, and any other contraption I build out of our favorite dtfb. I really like the versa for fpv, problem is, I fly fpv in weird locations without the plushest landing sites. I should probably rethink that, but these sites are so much fun. The landings usually require spot on accuracy if I want to touchdown on the soft bits, that is if they are even present, and I don't *always* nail it, you know. On occasion, this wing finds itself skipping merrily across craggy terrain or firmly ensconced in a thicket, chundered thusly, my wing generally has a short lifespan. Things start to get more and more floppy and the thing flies all wonky and what not. Since I have pretty much dialed most of my needs and mounting methods, I would like one to last a while. Any ideas? I tried bouncing ideas off myself, and it didn't work. I ended up in an argument with myself and said some things I can't take back. It got personal.
Anyways, the thing I have heard that sounds promising is filling the cavities with expanding construction foam. Then I suppose you could glue in some carbon spars and hack in recesses for electronics. Has anyone tried that? I'm curious about that, and unless I hear some glaring warning, I may have to give it a shot.
Another thought is it might be time to explore other building options. Maybe Sripol will inspire some depron action?
There's hot wire foam cutting too, but that's a whole big setup I'm not sure I want. It's just hard to give up five dollar airplanes from foam board, know what I'm saying? However, six airplanes later, cost is creeping up there.
Input appreciated! Curious if anyone has tried the expanding foam thing.
