quorneng
Inq
If you are vase printing there is nothing you can do apart from use a smaller layer height (0.15 or even less) but you have to accept the longer printing time. I believe there are slicers that allow the layer height to be varied during the print.
If you are not vase printing then add a top layer (or 2) and it will fill the holes but you might have to experiment with the top/bottom line direction to get the best result.
A 90 degree bend with 1 bottom layer to 'fill' the lower surface holes. 0.4 line width. 0.15 layer height
2 top layers to 'fill' the bigger top surface holes.
On such a print the extra weight from the extra print would be small and probably no greater than your 'glue' fill.
