Is 2306 too small for a 6 inch prop?
"Corpse"
Hey Ya'll! I'm sourcing parts for a chase/freestyle build and I'm wondering if a 2306 motor would smoke if I ran 6 inch props on 4s. Gotta save those motors!
JasonK
Power Pack A (2280kv 1806) works fine for a 6x3 on 3cell (indicated right on the store page). Obviously going up to 4 cell is something different, however your 6x?, the x (and if more then 2 blades) should matter in this case as they would effect the load on the motor (more load -> more current).
Does the motor in question have a spec sheet/recommended input/prop options?
JasonK
looking up a random 2306 motor indicates that _it_ can do 3-4 cell at 6in props. looking at another one, also indicates 3-4 cell, but only 5-5.5" props (higher Kv value). So, you definately need to look up your motor specs to see what it is rated for (or look up one as close to yours as possible if it doesn't have a rating sheet).
There is no way for us to tell, it depends on the Kv of the motor and the cell count you intend to use.
For some setups a 6 inch prop would be fine, other setups, not so good.
