Longbaorder23
Hey all,
im looking into bigger batteries for my quad for longer flight time. i currently use two batteries, a 5000 and a 2200. i use the 2200 strictly for acrobatics. it gets me about 6-7 minutes. the 5000 which i use more conservatively, gives about 15-16 minutes. im getting into FPV and I think ill want more like 20 minutes for some real enjoyment. question is, is it worth it to simply add a larger battery? Ive been doing some math about it, and it seems with 3s lipos available, these batteries are roughly 12mah per gram of battery total weight. if the cells are high quality then they can be around 13mah per gram. not the most accurate way to look at the matter, but its my take. I know that when it comes to adding batteries of high capacities to a model, the flight time is a bell curve. Meaning, if you put a battery much too heavy for the model (but it can still fly) the flight time is greatly reduced. if you put a battery very lightweight and small on there, the flight time will also be reduced. my quad is big, and 3.5 lbs without accessories or FPV gear. how high up of a battery capacity do you think i can put on it? is 5000 on the growing or shrinking side of the flight time bell curve? maybe a 6000 mah battery will do better? Any help would be appreciated. Thank you!
