Look at the pic below. In a nose dive crash onto asphalt yesterday, this battery took a beating as you can see. No sure exactly how it happened but should I still use it or get rid of it? It’s. It’s not puffy and it appears as though only the plastic wrap was torn but idk if it’s safe or not....
It might very well be ok; I've got a couple of batteries that have been a little beat up from quad crashes where the plastic wrap on it has come off.
That said, there's still a good chance that there's some damage you can't see. Have you tested the battery to see if there's any internal resistance on a particular cell, or if there's any wild variation of charge between the cells (i.e., cell 1 and 3 show at 4.17v, but cell 2 shows at 3.8)? That could indicate damage that's not visible.
If nothing seems to be the problem, then you can just throw a little electrical tape around the wrapper and continue to fly it - but I'd recommend charging it in a Lipo bag or something with some fire resistance, and monitoring it during the charge, to make sure it doesn't start puffing up, just in case.
