Guinea pig good first plane?
Draftman1
unfortunately joining a club is not an option due to the fact that the clubs around me an expensive fee that would be pointless to pay due to me moving across country in a few months
I’m not saying join a club and have a bunch of lessons, Most clubs will let you show up once or twice, have a good pilot check and test fly your plan, have them show you a few things, just to get the feel of it.
unfortunately joining a club is not an option due to the fact that the clubs around me an expensive fee...
It would still be worth checking out a local club.
Most clubs I'm aware of offers free flying lessons. They provide everything, the plane, the transmitter, the instructor. Everything is free. Having someone show you the basics will save you a lot of repairs.
Draftman1
Amen, you save a lot of frustration and rebuild.
Maidening a new plane when you don’t know how to fly is a recipe for disaster. Most pilots I know will have more experienced pilots maiden a new plane
I’ll probably call a few fields around me see if thy hav anything like that.
Another concern of mine is a lot of fields are requiring a AMA certification. Which if I’m being honest I don’t really want to spend the $80 annual fee but if it’s absolutely necessary I will.
I suppose mainly what I’m asking is are rc flying clubs super serious about the AMA certification Or is it more highly suggested?
...I suppose mainly what I’m asking is are rc flying clubs super serious about the AMA certification Or is it more highly suggested?
AMA clubs are serious abut AMA membership, you can't fly there without one.
But the AMA used to have a beginner program for newbies. You could "learn" for something like 3 months, flying on a buddy box using your instructors AMA membership. I'm not sure if the still do that, it was a way of getting people over the hump.
I believe I saw the 3 month trial certification which is $20 every 3 months which still comes out to basically even to the $80 a year
asher@caddo
i had my eyes on the XL scout for a second
Why are you going so big, I understand you think you will be able to see the orientation better, but just the same you will be needing a larger field where you'll fly farther away. Landing and everything will need more space. Also the cost, and size of the planes are much more then the minis. The Mighty Minis use same thickness foam and are significantly smaller and lighter, therefore when you crash its usually an easy fix rather then something like the guinea pig which has so much more intertia. The foam thickness is the same and much more damage can happen. I totally understand why a big plane seems fun, and it is, but start smaller is my recomendation.
Just an opinion from a little high school kid. Have fun, good luck, fly safe and responsibly!
Shurik-1960
The number of batteries in the aircraft model is determined by the CG of the model and the specific load on the wing. You can have a desire to load a large battery capacity, get into the desired CG, with a powerful motor -get a flying brick, the flight time of which will be quickly eaten by a powerful motor. Therefore, with an increase in capacity (weight) batteries to increase the flight time follow the path of reducing the weight of the airframe itself, increasing the load capacity due to a different profile and wing area...The result: increased battery + lightweight airframe = increased flight time with a normal specific load on the wing.
The Fopster
I think it would be a good idea to use a simulator first. There are some free ones - for example https://www.heli-x.info/cms/
If you have a computer you can connect to your transmitter you can practice until you can take off, fly a couple of circuits and then land again. A few hours doing that before trying it in the real world could save you a lot of grief.
Whatever you decide to do - good luck!
joelspangler
I did a TON of crashing when I first started a few years ago. Spent A LOT of time rebuilding and not much time flying. I eventually got sick of it, and did two things. I bought a super small and light "toy" plane that was almost indestructible. There are a lot of different options now, but the one I got was a wltoys F949. I wouldn't suggest the planes with two props that don't have an elevator, those get boring too fast, but a 3 channel (throttle, elevator, rudder) or 4 channel (adds aelerons) plane with EPP foam is a great trainer. The second thing I did was to buy some kits from https://www.crashtesthobby.com/ - specifically the Albatross and Assassin. It wasn't available back then, but the smaller Pelican plane seems like a great option... I've recommended it to a few people that seem to be happy with it. And I'd just go with the option with both wings so the plane can "grow" with you as your skills increase.
Flying Monkey fab
If lessons are out of the question, spend a few bucks on a RC sim and fly the daylights out of it. You can crash over and over without ever having to rebuild.
I feel like I should include some context.
I (20 years old) have been wanting to get into the rc plane hobby for well over a decade now but have never had the money or motivation to start. That all changed a last week when I finally decided to bite the bullet and buy a radio and receiver just to start. Mind you I’ve never even touched a simulator I did some research and decided to get the FLYSKY FS-ST8 transmitter. While I was researching radios I was also thinking about what plane I should get. After going back and forth between the Sea Duck and possibly the Legacy with a float kit (can someone tell me if that’s even possible). As you can tell I really wanted something that I could fly off the water. After annoying my girlfriend for her opinion. She said “if you get a something that can land on the water you’re gunna crash in the middle of the water and then have to swim out to get it” so I decided maybe not a float plane. I still wanted something twin engine and I found the Guinea pig bundle with all the electronics. I wondered if it would be a good beginner plane
(Well this isn’t exactly a question because its already ordered and shipped I’m just waiting for it to arrive and then build it)
A few side notes. I’ve watched the Flight Test build video for the big Guinea at least 3 times by now and I plan on watching it again when I build it. However I’m not a huge fan of the landing gear. However I did read someone’s comment on a Guinea pig post on this site basically saying that I can completely remove the nose gear and move the main gear closer to the nose so that it’s more of a tail dragger style and I really liked that so I might implement it when I build the Guinea.
I have also ordered 3 Lipo batteries and a charger. The batteries ordered are 2x2200mah 3s battery and one 4000mah 4s battery. I was curious if I could run the two 3s batteries by connecting one battery to each esc or would I be easier to run them in series. Also would the 4000mah 4s be too much for the stock esc that comes with the bundle.
P.S. yes I agree to those of you that are thinking I should have asked these questions before I ordered everything. But you live and you learn. Who knows maybe I’ll get a turbo tutor after this.
Here’s my two cents:
A: Try RealFlight it works really well and has almost every plane you can get from Eflite or Horizon hobby.
B: If you want to fly crazy attachments to planes like head tracking FPV get a FlySky or some other transmitter. If you’re mainly focused on just flying then get a spectrum. The DX6 is what I can use and it works perfectly.
C: The Guinea pig will not be a good first trainer. Buy an Aeroscout or sport cub, the Scout if you want FT.
D: My guinea pig takes two Spektrum 3s 2200 batteries to perfectly balance out. I HIGHLY recommend using spektrum batteries as they have smart technology and automatically discharge to a safe level after not I use for a long time.
Rhaps
And here are the last 2 full sheets for the hull
  • Sheet 3-Full.pdf
  • Sheet 4-Full.pdf
Rhaps
And last 2 sheets as single pages
There is a helper line in the hull parts, cut the print along them and align the line at the line on your cutting board and use the x-marks for horizontal alignment.
Note that there is only one hull side, you have to flip the paper or use hull side that you already cut out as a template.
For sheet 4 you can part prints are good because the parts fit on 1 A4/Letter/legal printouts
  • Sheet 3-Part 1.pdf
  • Sheet 3-Part 2.pdf
  • Sheet 3-Part 3.pdf
  • Sheet 3-Part 4.pdf
  • Sheet 3-Part 5.pdf
  • Sheet 3-Part 6.pdf
  • Sheet 4-Part 1.pdf
  • Sheet 4-Part 2.pdf
  • Sheet 4-Part 3.pdf
  • Sheet 4-Part 4.pdf
  • Sheet 4-Part 5.pdf
  • Sheet 4-Part 6.pdf
  • Sheet 4-Part 7.pdf
  • Sheet 4-Part 8.pdf
