I don't think you have it right. The way you have mentioned the motors to spin is correct, but the nuts you have in the wrong spot. If the prop is spinning clockwise, you will want the nut to tighten spinning CCW. If the prop spins CCW you will want the nut to tighten spinning clockwise. That way if any props slip it will only tighten the nut. I have the emax 1806 motors as well and my red nuts are on the top right and back left.
duh, than makes sense.. i will change them now while its on my mind.. thanks for setting me strait. like i said i can be stupid at times. i do think i will replace them with nylon lock nuts later on.. just have to remember to take with me next time im at home deopt.
chris
