Is each side of the wing 38", or is the total length 38".
It's a common FB build technique to use packing tape to to hinge the bottom wing surfaces together in the center and then hot glue the sections together when setting the dihedral. Then adding more tape to the top surface joint for reinforcement.
See any of the many FT build videos for planes with similar lines as that model.
