T-Ro
Well, my quadcopter is complete! I have learned how to fly on a Nano QX, now know how to build a quad, but I am having trouble learning how to tune my quad by myself.
I have watched many different videos over and over about P&I settings, what they do, and how to tune your quad. But I am still having trouble and I am sure that there is something that I am missing that will make the problem go away... but that is where the lovely community comes in.
My Set-up
Strange Things Are Happening
So, in my personal understand of P&I gains on the control board, the higher the settings, the greater the CB will want to correct shifts on the platform. You want to raise the P gains until you start to get an also oscillation, back it back down a hair and then you get your P gain settings. Then you move to your I gains. You simply want to make sure you platform isn't self leveling once you put it into an attitude.
But here is the strange thing: to keep my platform stable, I have a super low P gain settings (talking about 15).
If I lower the P gains into the single digits, I violent get oscillation. If I go above 25, I get violent oscillation. So I am stuck at like 15 or so for my P gains.
The oscillation that I get is very violent and enough to have it pretty much be flipping over. But if I hit the 15 or so values on my P gains, I can hover and stay pretty much still. But now the problem is that I can't actually fly patterns, because when I begin to move around oscillations pick up and will eventually make the platform erratic and uncontrollable.
These P gain values are just so low I know that I am missing something (knowing most people have their values around 60-100). But then again, I am new to learning how to tune my KK board. I simply have been messing around with my settings trying to find a sweet spot... the settings below are the best that I can do... but it doesn't allow me to do more than hover without oscillations.
Attached below are some pictures of my KK board, hopefully someone can spot something that looks off and I can learn a little bit more!
Self Leveling Settings (I turn off my self-leveling)
Profiles
P&I Settings For Yaw
P&I Settings for Aileron & Pitch (Linked)
Mode Settings
Version
My Set-up
- Electro-Hub
- Turnegy 30A Plush
- 1000 kV Motors
- 10x4.5 Props (Balanced)
- KK2 Board (Self-Leveling off, V1.17S Pro [can't update with my USB ASP])
- Spektrum 6-channel RX
Profiles
Mode Settings
Version
