Mr NCT submitted a new resource:
Landing Gear Attachment Panel - Main gear attachment panel
Read more about this resource...
This panel is designed to be permanently glued into the wing during assembly and then attach the landing gear once painting and trim are finished. It's supported by the leading edge and the spar on a swappable series size wing. The gear wire is held in place by small (3" or 4") wire ties. There are guides built in so the wire tie can be put in without access to the back of the panel. It also allows you to remove and replace the gear and adds a break point (the wire ties) for hard...
