laser cutter
#2
I've been working on a DIY laser cutter. I currently have a simple 3W laser and it is able to engrave and cut foam. I'm still working out how to get the FT plans to cut as they are much larger than my little laser cutter can handle.
mayan
I’ll be looking at this thread I too would love to find a way to cut out my plans using a home made laser cutter machine.
I’m no expert, I don’t believe you can cut white foam board with a 3w laser. I think you need something like 40w. Like @mayan, I would love to cut out my planes with a laser. My understanding, it’s the color of the foam, not the paper, that is the problem. A 3w laser can cut white paper but not white foam. The needle cutter looks like a great alternative to a laser.
Wildthing
I have a laser cutter and I think it is 2.5w, 6mm grey foam no problem but white foam it won't cut. I never tried it on foam board but if it is colored paper you should be fine. I can also cut 5mm balsa no problem but plywood is out.
Wildthing
@Merv and @Wildthing any ideas why it's not working on white FB and plywood?
If it is white paper then it won't cut it, the laser won't reflect off of white. As an experiment you could give it a quick paint job and try again but not sure if it would make it all the way through. Plywood you need around a 40w laser or so ( I forget what spec they recommend) , 3w is no where near enough power
#8
Folks I have a couple of 80 w’s & have been laser in for about 19 years now. There is a lot of yes & no’s to these questions.
(And no an 80w is far from ideal for cutting foam board...though it can be done)
So first allow me to mention I will take a conservative approach to my take on things here.... yes a 40 w is a good place to start...BUT...
It partially depends on who makes the parts & where they come from... not all wattage parts are created equal. Nor is all Chinese parts or lasers... important to remember the laser parts are important just as is the software you are using. And not all Chinese software that comes with some of these units are useable
Many want to get into lasers as cheaply as possible... this is an area where you truly get what you pay for. I see a lot of folks try to go cheap as that’s what they can afford... only to have to throw away what they bought or invest in yet more parts & upgrades.
Cutting plywood depends on how many layers of ply & glue & what kind of glue is used. I can cut 1/2” ply on one of my lasers but not the other....but again only some types. Similar rules to foam board....chemical/glue involved & the paper used.
I don’t discourage those who like to tinker & build... but go into this understanding lower wattage & cheap is not. A great lace to start.
Lastly it may be a better option to find someone local who has a laser & cuts commercially... bring your file in & have them cut for you... it can be a lot cheaper.
#11
Re EBay 40W lasers... have a look at the attached pic... there are a lot of versions of these out there, but essentially most use the same parts & software. Typically they are known as K40’s. they were designed to engrave rubber stamps.... so ask what software they come with, does the unit have a water cooling system (what kind) & does it have an air system on the nozzle. You will almost need those pieces. So buying those are almost always extras.
I haven’t used these myself, but guys with a lot more experience then I suggest passing on them and buying a different unit... particularly with software that will work with PDF, def or svg formats. Chinese companies do many things to just offer a lower price...so make sure you find out what is missing. Not all Chinese lasers are bad...but the K40 ones need a lot of help to be useful.
So it is possible to cut white foam with a three-watt laser. By slowing down the laser and increasing the power I'm able to cut through the foam. That being said the cuts look more like burn marks and they tend to be fat lines rather than crisp lines like the ones from Flite Test speed build kits. I'll probably just convert the laser to a hot needle at this point.
buzzbomb
I know nothing!
#13
Umm, I know this guy, who knows a guy. He laser cuts DTFB. It leaves some burn marks on the bottom paper, but he's made it work. He keeps a low profile. If you want, I could drop him a PM and ask for specifics, which I won't understand, but could possibly pass on to this thread.
Wildthing
I played a bit with my grey Depron which it cut ok but I really had to play with the settings so the cut wasn't 3mm wide and I got it pretty good but still I wouldn't use it for building a complete plane. White foam would be worse to do, all you are doing is melting a thick line .
#15
I have a 10w diode laser, and have successfully built foamboard planes with it on my CNC machine. It doesn't cut all the way through the foam board, but it does easily cut the paper backing. If you etch the paper on both sides of the foam, it is easy to follow the score lines with a knife to cut it out, or break the foam along the straight lines. You just have to prepare a mirror image of the top-side pattern to cut on the back side of your material, and place some reference marks on the mirror line for maintaining alignment. You don't need 10W to cut the paper, so I am sure that a lower power laser could do this also.
