Updated: The parts came in so today I finished building, tested, cg, retested and touching up the Scout. As a first build, I made my share of mistakes, but the mistakes become obvious as I proceeded (so I stopped to correct them). The plane came out pretty well, but with no experience, I spent too much time on cuts that didn't matter and not enough time on cuts that were very important (The downside of doing a scratch build for your first build). All part of the learning curve (and for me, a big part of the enjoyment). So it's fully operational, 4 channel, B Power Pack, and AR 620 receiver.
I'll likely maiden in the next week or two (as I'm still learning to fly with the Crash Cub).
So Thursday night my new transmitter, DX6E, came in. I spent a fair amount of time learning how to program it and programming the Crash Cub in there. It goes through double A batteries like nobodies business (at least while programming). I set up 3 modes for the Crash Cub, low rate, 70/30, med rate 85/30 and hi rate 100/30. I also did that for the Simple Scout.
So Friday morning I took the Crash Cub out with the new transmitter. Wow! What a difference, that damn $3 game boy transmitter that came with the Crash Cub was about 80% of my problems. I don't need beginner mode with this transmitter when I put it in the low rates. I flew in experience mode and at one point, I wasn't sure if it was in beginner mode (so I had to double check) because it was so damn easy. But later, the wind picked up and beginner mode made quite a bit of difference. The $3 game boy transmitter had two faults, one it was way to sensitive even in low rates (so I porpoised all the time) and two it would lose contact with the plane often (so I flew close). Expo makes a huge difference! (at least for me).
So Friday was the first day that I really felt like I was flying the plane and not the electronics. I also did my first loop (but really sloppy). I'm hoping to get a couple more flights with the Crash Cub before I maiden the S Scout. I want to mess around with the Scout some more, make sure everything is solid, recheck the cg and taxis it around the driveway. I also want to learn everything I can from the Crash Cub before I go out with S Scout. I'm trying to be as prepared for maiden day as possible.
Oh, a side note: I used the flossing pick for the horns. However, I found an issue with the picks, the holes were too big creating slop. I filled the hole with jb weld (my go to) and pushed a large pin through it. worked great, removed the slop.
