Hi!
I just gave the cheap-n-easy wing a try and we were able to fly it. The build came out to be a bit heavier than I wanted but that is to be expected with the battery and motor I had. I think I also have a bad servo on the elevator - it starts shuddering if the elevator is pulled all the way.
Right now the AUW is about 275 grams. It has:
-- 2204 2300 kv motor with 5x3 prop (26 grams)
-- MG90 servo (2x 14 grams each)
-- 3s 700mah lipo (68 grams)
-- turnigy plush 20 amp esc (16 grams)
The foam with dollar tree foam with paper on both sides.
I have the 3s 700mah and 2s 850 mah and would like to stick with these voltages as I would not want to go into 4s.
Is it possible to make this even lighter - I would like to use light motors and smaller props. Would the emax 1306 4000kv work with 2s and 3s?
As for servos I might give the emax 9051 a try. I just want to ask before I start spending money.
Thank you in advance.
