An update has been long overdue, and I'm glad to present the newest version of the P-40. I've been extremely busy with school and other things, but in all the spare time I managed to scrounge up, I've been working on this plane.
Everything's been fitting well, all the parts go together great, except for this one piece on the hatch
It came out completely wonky and didn't fit at all, strange because that's the only piece that didn't fit. It did have some weird curves that maybe the unwrapping algorithm had trouble with.
Some pictures of the plane so far:
The connection between the wing and the fuselage fits very nicely, and it is oddly satisfying how everything fits together. maybe it's just me.
The area that the fuselage skin fits to the wing has a small gap, but that's just builder error. I glued it so that one side had too much material, and then sanded it away to make it flush (or at least less crooked) but I accidentally sanded too much. Now both sides have an uneven fit!
I sure won't make that mistake again.
The hatch fits decently, although it requires a lot of sanding. I forgot to include a coupe pieces in the plans! (the cowl flaps)
The tail of the plane is like most master series planes, more specifically the new minis (you cut a slot in the formers after assembly and then feed the backbone in). I can never seem to get the bottom of the tail right, and it always comes out with a gap.
The tail:
Bad joint:
I have since revised the tail to have two seams down the sides much like
@Grifflyer's mini spitfire. It's much easier to form and with a good paint job can be disguised as panel lines. I have already built a test part and it works great, but unfortunately I don't have pictures.
I never realized how big this plane was until I actually built it! That's part of the reason the servo tray is so far from the tail feathers - I completely misjudged the difference. To rectify the situation as well as make things easier on the builder, I think I'm going to opt to have the servos embedded in the horizontal stabilizer and partially obscured by the tail. (I haven't built a model of that system yet, but hopefully one is coming soon.)
Anyway, progress is slow but steady, and I want to release the best version of this plane that I can, so thank you for all your patience, especially
@Slamador!
