Hell2Go
I designed a flying wing at 30inches then did one at 20 in and another at 45 inches to compare the flight characteristics of each.
the 20 inch was wicked to fly, and cg was really touchy. it reacted faster than I could so I put it into the ground a lot. my son could handle it though.
the 45 inch needed a huge motor for the performance that I expect out of my planes, used a 4240-1300kv with a 10x7 with a 3s 2200mah. it had unlimited vertical and could see it well anywhere on the field but rolls were a little slow and my servos were underpowered causing random reactions under high stress situations. it had great gliding abilities. might upgrade to larger stronger servos an it would be a fine flyer. top speed was limited to around 65mph due to a thick highlift airfoil.
the 30 inch is more or less perfect! it supports a wide range of common motor sizes from a 24g blue wonder for nice gentle performance with a small 3s, to sky tearing flaming performance with a 2826-2200kv with a 5x5 and a 1300mah 4s with a thinner airfoil will put the wing into th 80 to 90 mph range. with a thicker airfoil it is limited to about 80mph but still has good low speed qualities too.
the 30 inch was my favorite and is still my goto plane. at the moment it has that little red motor that is so cheap http://www.hobbyking.com/hobbyking/...ner_1200kv_USA_warehouse_.html?strSearch=2822
using an 8x6 with the 1300mah 4s im getting about 70 mph and 8-10 min flightimes and a lot of fun.
I need to do a build log and article on the 30in wing as it is a quick easy build, cheap and massive fun. I can build one in a day and be flying before dark.
actually my avatar is my son's 30in and my 45in. my son is 11 and that was his first build and it flys better than mine! he likes to show off by putt-putt-putting by at about 5mph on the first low flyby for someone watching him for the first time, and they go "ooh aah!" then on the next pass he will rip past at about 80mph and they say "OH MY GOD!" then he'll do another pass blistering by inverted 3ft off the ground then as he passes goes vertical into a rolling climb till it is literally out of sight, then they say" HOLY SH*T!! That boy can fly!!!" then he just smiles that little smile that shows that he is proud of himself.
