Definitely Beta!!!
Okay,
So I finally got some flite time on the little guy. Here's what I've learned:
THE BAD:
1) I had the CG WAY too far forward, causing very sluggish flight - moved back and it's working better. I'll post when I find the sweet spot
2) Ailerons to the wing tip --- BAD IDEA - tips stalls like mad. I am going to cut the last 2.5" on each aileron and fix in place with slight wash out. If that works as hoped, I'll make a new wing. I had to reduce aileron throws and fly with the tailerons active for roll - worked pretty good. Once I modify the wing, I'll also make sure I have a fair amount of aileron differential. The down aileron, especially extended to the tip, causes a lot of yaw. Combined with tip stalliness - bad juju.
3) Underpowered. It flies OK with the 1806, 2300kv, but needs almost 80-90% power to fly decent. I'm going to update the motor to a Park 370 Zoom. Since the CG was off, this will actually work because I have plenty of room to move the battery to offset the heavier motor.
THE GOOD:
1) Really rugged design. Since the wing is not permantly attached, it has survived many trees, a split rail fence, and a stall/spin from 20ft. Nose is a littled dented, but not much. Wing moves on impact, really minimizing damage.
2) Design is easy to tweak - new wing is just that, nothing else to mod or change - I like that.
3) Tailerons work well - to tame the tip stall, I cut wayyy back on aileron throw, and it handled well
4) Looks really cool in the air....
New update when I get the wing mod done and bigger motor....
Kevin
