Grifflyer submitted a new resource:
Mini Master Series Spitfire - A Spitfire built using master series techniques
Read more about this resource...
When I set out to design the Spitfire, I wanted to try keeping things simple and easy to build for a Master Series plane. I chose to go for a fuselage that has an inner frame that then gets skinned in foam, rather than taking the "mold together" route that Overstreet uses. I put a lot of work into adding the scale details using just foamboard. Like the large wing fillets that characterize the Spitfire, and all the radiators under the wing, and I even went as far as adding little exhaust...
