F2G2Corsair
Hi everyone. I've been lurking on Flite Test for some time, and thought I'd share an idea I have. I've been experimenting with many waterproofing methods for my swappables, and I've come across a method I haven't seen used before.
I'm sure you've heard of using polyurathane minwax to waterproof a plane, but did you know they sell minwax spray too? I decided to try it on a few scraps of foamboard, and I've found it to be hit or miss, but when it works it's just as good as regular minwax. Typically I stand with the nozzle about a foot away from the plane and slowly circle the aircraft while spraying every last inch of it, which takes about 15 to 30 seconds, then I let it dry, flip it over and repeat. If you get too close the paper comes off the foam immediately and warps it, so be careful and practice a few times. I did this outside on a sheet of cardboard just so you know. I've found this method to be faster and cleaner than applying minwax with a brush (did you notice the Top Gun reference lol).
I noticed the Clear Gloss minwax spray doesn't require you to shake the can for 2 minutes before use, unlike the Clear Satin kind. I plan to use this method on my next build, a swappable Pizza Box Flyer.
One last thing, don't try using minwax spray in a windstorm. It was nice and convenient at first because the wind pinned the foamboard to a fence for me, but the moment the wind shifts it's gonna spray all over you lol! I was just lucky it didn't... And don't leave your plane out to dry at sunset, if the temperature changes it'll turn into a taco!
