So, I found a clean spot on the workbench and it's time to get back to work on this one.
Next up was wrapping aluminum ducting tape around the rest of the DTFB formers for the hotwire
Cutting out enough blank chunks of foam to rough out the rest of the fuselage.
I had to cut some straight ends on the blanks to connect them together. Not shown is I have them staggered in length so there is at least a 6" to 8" overlapping seam rather than all of the slabs lining up for a single (weak) vertical seam.
Then it was time to clamp the new slabs to the old slabs and clamp that to the table.
And hotwire!! This side is rough cut.
Needed to step back to family duty for the evening, but tomorrow I'll do the rough cut on the other side.
Then I'm going to take a couple pieces in the middle out of the pile and cut some long channels for routing wires. And cut out the top layer or two of the turret holes. Then add a couple long wood strip spars before sealing the pieces together and cutting the angled parts of the windshield, nose, and tail.
And then put this part to the side while I build a canard.
