So got to do a quick test flight at lunch, didn't really notice a big difference with damped light enabled but didn't really expect one. With the 12a BS ESC's on my mini I noticed a bit of a difference but not nearly as much as the KISS make so on this larger setup with bigger props that carry more inertia I expected even less of a difference and that was about what I got.
I did notice the motors and ESC's were a bit warmer than normal after just a short flight though.
I didn't get video of autotune because I didn't get to try it until after dark. But I did get fairly different results even though the handling is still very good and the damped light effect isn't all that noticeable.
Original autotune results with BLheli 12.2 and no damped light:
Measured properties
| Gain | Bias | Tau(s) | Noise |
Roll | 9.28895 | -0.0358139 | 0.047 | 464.107 |
Pitch | 8.88793 | 0.00654138 | 0.047 | 563.658 |
Tuning aggressiveness
Damping | 1.1 |
Noise sensitivity | 1 % |
Natural frequency | 3.9 |
Computed Values
| RateKp | RateKi | RateKd |
Roll | 0.00187589 | 0.00373083 | 6.45268e-05 |
Pitch | 0.00280135 | 0.00557141 | 9.63607e-05 |
Outer Kp | 3.65604 | - | - |
Derivative cutoff | 13 | - | - |
And revised results after upgrading to BLheli 13 and enabling damped light:
Measured properties
Roll | 9.73757 | -0.0127094 | 0.0342 | 82.1875 |
Pitch | 9.20915 | -0.0230826 | 0.0342 | 166.793 |
Damping | 1.1 |
Natural frequency | 5.4 |
Computed Values
Roll | 0.00164897 | 0.0045102 | 4.13095e-05 |
Pitch | 0.00279709 | 0.00765045 | 7.00715e-05 |
Outer Kp | 5.02803 | - | - |
Derivative cutoff | 18 | - | - |
Things that jump out at me...the noise readings went down significantly from the 500 range down to the 100 range. Tau went down as well (though I'm still unclear on just what that represents...I'm starting to understand but haven't reached the point where I can describe it yet)
The natural frequency went up. But the PID values went down for P and D and up for I. The outer P term (which is what controls auto level I believe) went up significantly.
Not sure just what to make of these changes since I'm still learning how the Tau Labs PID controller works. It did feel significantly more locked in after the autotune. I'm thinking about disabling damped light and doing one more try just to have more consistent data with the same version of blheli and the frame in the same condition (it's had a few bumps since the original autotune and isn't quite as flat as it was so that may have affected performance some.)
Just may not get to try that for a few more days as we've got 25-35 MPH winds predicted for the next two days
I may try tonight still...it's calm out. But flying this thing at night is tricky even with all the LED's I've got on it I really need to put some on the top and/or bottom of the booms as well to help tell how much tilt I've got going on.
Plus I still want to get oneshot working on this setup to see how that does. Still not sure why I can't get it working and the goofy USB issues on Linux are keeping me from being able to calibrate the ESC's when oneshot is enabled.
